vwnut8392
63 standard dr
Has anyone here come up with a real launch control solution? i have tried to use the secondary mapping and retard ignition timing but the engine still pushes to the rev limiter and makes very little boost. what it needs is something to cut spark on and off at a specified engine RPM along with the timing retard and fuel enrichment. i have been trying to use plex's code to try and figure out a solution but i just cant figure it out. any help would be great. sorry that i dont speak russian. oh and my car is converted to turbo as well.
vwnut8392
63 standard dr
[QUOTE = "ScH, post: 278205, member: 1477"] Hi. Launch has yet on the table, but not tested on road. Waitin dry roads / 1-2 months [/ QUOTE]
If you would like it to be tested i will test it in my digifant 1 2.0 ABA sand rail buggy and let you know how it works. its a nasty little toy in the woods :).
vwnut8392
63 standard dr
Does the data logging work without any sort of USB to serial converter? i have read the instructions here (https://github.com/AYastrebov/VW_G60/tree/master/USB) and they make no sense. i understand the 1K ohm resistor from R61 to R14 for output of data to pin 21. i dont know where to get the specific USB to serial module used to complete this or if it is even necessary because in this post (https://www.drive2.ru/l/7763833/) it looks like he has the USB cable connected straight to the ECU and it is functioning. so does putting the 240k ohm resistor on top of R219 allow you to not need a USB to serial converter anymore? how does the computer recognize the port without a converter?
On connecting the LC-1 to the digifant do i use the 0-1v output or the 0-5V output? do i feed the signal into the standard lambda signal wire? someone please help. sorry, i only speak english.
There is no experience to get data from digifant without usb to serial connector.
You can try to find this device like "prolific usb-to-serial comm port". A few years ago this adapters were used to connect old Nokia mobile phones to the computers.
Second link which you wrote, guy also used adapter, but different kind.
Regarding lc1: I haven't experience, sorry
vwnut8392
63 standard dr
I have prolific USB to serial adapter but a different kind than the others used.
This is the kind that i have.
I took it apart and extracted the board inside and removed the serial connector. the board is very small so it could be mounted inside the digifant ECU easily. i did not have a 240k ohm resistor but i did install the 1k ohm resistor on R61 and instead of putting it to R14 i fed that straight to pin 6 on the serial side of the USB to serial converter. should i put the resistor to R14 than put a wire from PIN 21 on the ECU connector to pin 9 on the USB to serial converter?
zazikns
гомель
Всем доброго времени суток!подскажите как с эбу прочитать прошивку,точнее как подключится к микросхеме!нужно сдвинуть отсечку!помогите если можите!эбу привозил друг с америки!читал блинк коды ошибок нет!
Выше есть ответы на твои вопросы.
zazikns
гомель
это я уже читал не один раз!меня интересует чисто как подключится к мозгу и што для этого нжно?как менять таблиы думаю разберусь !
Прошивки считываются с микросхемы программатором, например MiniPro TL866CS
По-умолчанию фольксваген не дал никаких интерфейсов типа k-line, obd и тому подобное.
Для сдвига отсечки нужно править карту разбивки частот. Попробуй загрузить прошивку в программу, выложенную в указанной теме и посмотреть, корректно ли она распарсилась
Хотя если чип из америки, то скорее всего там будет прошивка с 1 картой зажигания, а не 3х под которые написана программа. Тогда сложнее и нужна TuningPro и xsd-схемы под этот чип. На форуме есть ссылка на мой дропбокс, где все это выложено.
После правки таблиц прошивку заливаешь программатором на чип и ставишь в мозг. Если чип не 32к, нужно продублировать прошивку в старшие адреса
Реакции: Neuss
zazikns
гомель
С большего понял!спасибо!просто счас езжу на пг с турбой впринцепи все устраивает кроме отсечки,летом ехал квотер за 15 с мелочью!а вобще уже лижит KR тоже с трбиной,буду ставить по весне!а поскольку тут писали што полюбому придется менять прошивку и настраиваться вот пока буду тренироваться!а вобще месяц назад заказал с EBAY чипованную микросхему но там отсечка такаяже и разницы в приросте мощьности не ощитил совсем!хочу заодно сравнить её с родной!а пришла вот такая за почти за 30уе.
Vustrik
Могилев РБ
если пост не несет смысловой нагрузки затирайте нафиг
итак: хотел увидить что происходит в моторе просто и быстро на мониторе пк
имеем ноутбук с Win 7 (64)
вот такой модуль ( https://ru.aliexpress.com/item/2pcs.../1297727781.html?spm=2114.13010608.0.0.zO3CWK )
чип в нем но нейм - поэтому драйвер 3.3.2.105-определяется как Prolific
резистр на 1ком подключил вот так
RXD на 21
GND на 13
WP_20170421_18_39_14_Pro.jpg WP_20170421_18_39_42_Pro.jpg WP_20170421_21_30_08_Pro.jpg
уважаемые знатоки - что не так?
Ну как минимум - стоковая прошивка не делится данными через COM-порт
Vustrik
Могилев РБ
я просто фиг уже знает что может быть .взял прошивку которая точно делиться данными .проверил отдельной прогой работоспособность чипа pl2303 . На нем видно что моргает передача при запуске мотора .а в программке диги от кда ,один черт пустые окошки
@Vustrik проверь скорость перелачи данных.
Также есть 4 версии программы, все они передают данные по разному. При не той версии будет расти счетчик ошибок, тк не сходится контрольная сумма переданных параметров
Vustrik
Могилев РБ
какая нужна скорость? проверил все 4 версии
как узнать какая у меня прошивка ?
