Come on folks.
Don't even *blink* until your oil temps hit 235+F(112+ по цельсию).. the VR6 doesn't.
It'll happily run 230's() all day long and it's possible to see 250-260(121-126+) if
pushed hard on the highway, like A/C on, 104 degrees out, uphill.
And if you run it on the track, it's good till about 280F(137), and then
you should consider backing off a little. Mine's seen just a tick
over 300F(148+) on the track and is none the worse for wear.
When I see people worried about oil temps of 200-210.. I seriously
gotta roll my eyes. The VR6's *optimum* temps are between 180F
and 210F, and it's only mildly warm in the 210-235 range.
There should be something in the VR6 FAQ here.
The VR6 RUNS HOT and that's normal!
переводить надо?
свиснуто на
www.vwvortex.com
