Вес разных частей рады
VR6 Glock
удалите меня, а :)
конечно, спасибо вортексу, вот что человек снимал и взвешивал.
2 - G60 Power Window Motors = -------------------------- 2 lbs. each
1 - G60 A/C & Heater Box (behind dash) = -------------24 lbs.
All G60 wiring (Radio, A/C,Seatbelts,power doorlocks)--17 lbs
G60 A/C & Heater tubes = ---------------------------------2 lbs.
1 - G60 Center Console = ---------------------------------2 lbs.
1 - G60 Radio = --------------------------------------------3 lbs.
1 - G60 Ash Tray = ---------------------------------------1/2 lb.
2 - G60 Rear Seat Cushions = -----------------------------4 lbs. each
1 - G60 Drivers side rear seat back = --------------------10 lbs
1 - G60 Passenger side rear seat back = ----------------13 lbs.
2 - G60 door panels = --------------------------------------6 lbs. each
2 - G60 rear panel = ----------------------------------------3 lbs. each
1 - G60 A/C Compressor & all hoses w/condensor = ----35 lbs.
1 - G60 Sunroof Assembly = ------------------------------21 lbs.
1 - G60 rear wiper assembly = -----------------------------4 lbs.
1 - G60 head liner = ----------------------------------------2 lbs.
2 - G60 Sunvisors = --------------------------------------3/4 lb. each
1 - G60 Door lock pump = -------------------------------2.5 lbs.
1 - G60 Antenna Base = ---------------------------------1/2 lb.
1 - G60 Front Wiper Assembly = ---------------------------6 lbs.
G60 Interior Sound Deadening (Includes Sandbags)=x. 25 lbs.
2 - G60 Seat Belt Tracks = ----------------------------------3 lbs. each
G60 Front and Rear seat belt accessories = --------------10 lbs.
G60 Spare Tire and jack = --------------------------------34.5 lbs.
G60 Stock Battery ------------------------------------------24 lbs.
Stock VR6 Hood = ------------------------------------------39 lbs.
G60 Stock front seats = ------------------------------------44 lbs. each
G60 Kneebar with pads = ----------------------------------25 lbs.
G60 Steering Column Trim (Includes steel plate)= ------1.5 lbs.
VR6 Suitcase Pre-muffler = --------------------------------39 lbs.
Stock G60 Airbox with K&N filter = --------------------------4 lbs.
Vibration dampener brick on the subframe = ----------10.2 lbs
вот и первоисточник
http://forums.vwvortex.com/zerothread?id=3427836
спортсменам и не только оччень пригодится
Круто! Я даже такое дело переведу в КГ...
2 - G60 мотор эл. стекла = -------------------------- 0,91 кг . каждый
1 - G60 Кондей & Радиатор печки = -------------10.8 кг
Вся G60 проводка (Радио, Кондей, Ремни безопасн., ЦЗ)--3.4 кг
G60 Кондеые & печки патрубки = ---------------------------------0,91 кг
1 - G60 Центральная консоль = ---------------------------------0,91 кг
1 - G60 Радио = --------------------------------------------1.36 кг
1 - G60 Пепельница = ---------------------------------------0.22 кг
2 - G60 Обивка задних сидух = -----------------------------1.81 кг каждый
1 - G60 спинка заднего сиденья за водителем = --------------------4.53 кг
1 - G60 спинка заднего сиденья за пассажиром = ----------------5.89 кг
2 - G60 дверная обивка = --------------------------------------2.72 кг каждая
2 - G60 задная полка = ----------------------------------------1.36 кг каждая
1 - G60 Компрессор кондея со всей бедой = ----15.87 кг
1 - G60 Эл. люк = ------------------------------9.52 кг
1 - G60 Задная часть проводки = -----------------------------1.81 кг
1 - G60 head liner = ----------------------------------------0,91 кг
2 - G60 козырьки = --------------------------------------0.34 кг каждый
1 - G60 замки дверные = -------------------------------1.13 кг
1 - G60 Antenna = ---------------------------------0.22 кг :grin:
1 - G60 Передняя часть проводки = ---------------------------0.22 кг
G60 Шумка --------------------------------------------- 11.33 кг
2 - G60 направляющие ремней безоп. = ----------------------------------1.36 кг каждый
G60 передние и задние ремни безоп. = --------------4.53 кг
G60 ЗопаскО со всей бедой = --------------------------------15.64 кг
G60 Акум ------------------------------------------10.88 кг
Stock VR6 Капот = ------------------------------------------17.69 кг
G60 Stock передние кресла = ------------------------------------19.95 кг каждое (а вот тут вопрос... какое? механика/электро и кожа/ткань?)
G60 нижняя часть торпедо (упор для коленей во время удара нах! =)) = ----------------------------------11.3 кг
G60 Рулевая колонка (Includes steel plate)= ------0.68 кг
VR6 Suitcase Pre-muffler (походу весь выпуск без банки) = --------------------------------17.69 кг
Stock G60 Коробка с воздушным фильтром K&N = --------------------------1.81 кг
Балансировочный груз на подрамнике = ----------4.62 кг
з.ы.: мне каждется мои кожанные электро рекары больше 20 кг весят... я даже взвешу их ради интереса!
на счет передних сидений, думаю это вес механики+ткань... на вес они не легкие, проверял, поэтому думаю они так и весят.
на счет задних сидений, наверн имеется ввиду вместе со спинкой, а она не 50 на 50 % складывается, а 60 на 40, отсюда одна тяжелее, другая легче.
посчитал, что сняв все то, что можно было снять\поменять, я снял у себя около 105 кг, правда, поставил вместо этого нечто другое. поэтому, допускаю облегчение на 40-60 кг, может больше. надо будет потом взвеситься на весах.
p.s. на счети виброизоляции, там говорицца о виброизоляции подрамника. что это имеется ввиду, знает кто?
Glock, этож походу кирпич который на подрамнике привинченный №12
http://www.elcats.ru/vw/scheme.asp?mdl=1578&pid=7EC01824
по весу так подходит
Tom... написал(а):
G60 Педальный узел = ----------------------------------11.3 кг
всборе с абсом штоли? ))))))) или к нему ботинки на свинцовой подошве приклепаны? ))))
согласен... чото не то. нашёл чо такое ниибар вив пэдс... :)))
кому интересно чо это, оно тут
знаю как на одном пг её покрасили в красный цвет и машина стала заводиться с 3 раза тока... стрёмная деталь короче о_0
ваще интереснее былоб еслиб был вес дверей, рычагов подвески, тормозов (!) балки, крышки люка, тормозных дисков, дверных стекол, третей двери итд итп--т.е то, что сильнее всего влияет или то, что можно облегчить.....
надо взвесить и выложить(у кого-что снятое есть)...интересная тема будет!
Новгородские пластиковые крылья по 3,5 кг каждое. Пластиковый капот вроде 7 кг.
